G transmission oil
FreeRange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FreeRange Quote  Post ReplyReply Direct Link To This Post Topic: G transmission oil
    Posted: 05 Apr 2012 at 10:00am
I'm working in on a G project. The transmission oil level is very low, so will drain what is left and replace. From what I've been able to find, capacity is 6 quarts.
What is the preferred type/weight of oil to use in the G transmission?
And is there a known weak point I should be checking for a leak?
mmccarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmccarty Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 12:25pm
The original manual called for a 20W trans oil.  Any of the universal trans/hydraulic oils on the market would be suitable, generally they are multigrade 10W20 or 10W30 oils.
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 1:52pm
yep, I just use hytrans NAPA, Walmart, wherever I happen to be buying a bucket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FreeRange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:55pm
Got it, thanks.
(got to buy something actually tractor related at Tractor Supply)
