WF axels
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Topic: WF axels
    Posted: 18 Mar 2012 at 6:52pm
Tore down my unstyled wf to put new seals in the rear end both axels are split out on the ends where the gear bolts on to the end of the axel at the keyway,I dont suppose anyone has any axels and they are probably not available any more any help would be apreciated THANK,S Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 8:38pm
Bump
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 9:33pm
Is there a difference between WC and WF axles besides length?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 12:31am
Are you talking about the pinion shaft? If a good machine shop doesn't want to repair yours, it may be possible to cut a set from a WC down. I know of a good machine shop, used to work there for 15 years:)
 I have fixed shafts before that split at the bottom of a keyway. Ya gotta grind past any hint of a crack and weld it all up, recut the key seat. Some people might think you shouldn't weld on em but I have seen crankshafts from up to a 16 hundred ton forge press welded up and reworked.
Edited by CTuckerNWIL - 20 Mar 2012 at 12:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 9:24pm
I work at a machine shop and i will  probably weld them thier is a pretty good variety of welding rod out know for welding different types of steel , it split the piece out so it won"t take a lot of weld, machine and recut keyway when I reassemble I'm going to switch the axels from side to side that way all the torque will be on the old part of the axel when going forword on the weld in reverse
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:12am
You might contact Lester  Copeland in Depaul,Indiana. I don`t have his number.
"Burgie"
