200 allis hyd. pto wont stop
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis hyd. pto wont stop
    Posted: 18 Mar 2012 at 3:29pm
Workin on that 200 and now noticed the pto wont stop when the brake is applied , its got full power going to it as you cant stop it by hand ; anyone knopw of a reason for this , or can tell me how the brake works - i,ve been looking at Agco parts online and the - fix it manual - but maybe some one can explain it better
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 7:20pm
         I don't know if a 200 is the same as a 190XT but if it is the arm going to the valve under the floor pan could be out of adjustment. Also there is a bushing that wears out on the shaft that goes toward the valve.
                                 John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 7:19am
The brake is pads on the end of two pistons that push against front of clutch housing. Brake is mostlikely not the problem. Worped or broken plated. MACK
