styled wc speed patrol
firecowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Topic: styled wc speed patrol
    Posted: 16 Mar 2012 at 8:54pm
what is a good running styled wc speed patrol worth
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:57pm
What shape are the tires? Is it original or has it been converted to hydraulic? Is the front end bolted or welded on? Does it have the serial # tag? Could be from $2500-$4000 maybe to the right person in the right condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:58pm
needs tires orig paint welded front  not converted to hydralic
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:59pm
thank you for any and all help
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 2:05pm
serial no is 1e 1289
Smile
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 3:25pm
What dose the guy want !!!!!
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 5:30pm
   When did the W patrol switch from bolted to welded ?
Edited by Rfdeere - 17 Mar 2012 at 5:42pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 5:36pm
The ones built in LaPorte thru 1942 were bolt on and from 1945 until the end they were welded on and built in the Spingfield plant.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 5:38pm
I believe after they went back into production following ww2 but I could be wrong, we have a 41 and a 46 the 41 has bolts and the 46 is welded and I dont brlieve they were made during the war
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 5:45pm
   Thanks ! I was thinking that.
