All-Crop Rebuild Pics 2-4-2012
 Rating: Topic Rating: 3 Votes, Average 3.67  Topic Search Topic Search  Topic Options Topic Options
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop Rebuild Pics 2-4-2012
    Posted: 04 Feb 2012 at 6:43pm
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 6:57pm
Looks awesome Tom!  Thanks for the update.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 6:58pm
Tom,
I have been following your 'new' All Crop build since the beginning, like everyone else. This has got to be one of the coolest projects, that I have ever seen on here.
Keep up the great work!
Don
Galatians 5:22-24
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:05pm
That, Tom, is gorgeous!  I can appreciate the time and work you are putting into it!  keep it up!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:07pm
Thanks guys..
You notice anything peculiar about the grain pan pic?
1. Has a cleanout.
2.  The above shaft that turns the pitman is NOT wrapped in the metal from the above table.  That is because the shop bent the wrap too tight. Cut it off. For the better anyway. One can now keep that shaft well oiled so it can be pulled out during servicing. Otherwise when wrapped by the tin, you cant get to it and it gets rusty, making pull out problematic.  Verision 2.0 of that table will have a bent hood over the shaft instead of
the complete wrap around giving it the sheilding but still can grease it.
3. Of course you guys see the fan bearing replacement....is "off the shelf" but was still hard to size. The distance between the center of the bearing and top flange had to be tight so the fan isnt mounted too low causing it to hit the fan housing bottom. Only found this one make that had such spec.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:17pm
tom. keep at it. will have 20 acre of beans for you to take off this fall when you swing through ohio with the all crop "bean special". sweet...........tp studer. wooster,ohio.
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:32pm
Tom, I am going to go out on a limb here and say the allcrop has more parts on it than the chopper I just finished.  Good work.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:51pm
Very nice work Tom!! I enjoy all the updates you post about it! Looking forward to seeing field trial photos. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:37pm
Took a look at your chopper; actually I would think yours is more complicated than mine.
Dont let the large size of mine fool you..
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:45pm
Tom, it looks great.  Will it have as many grease fitting as the original?  That was my job to grease it when Dad pulled it out of the shed, have forgotten how many were on the 66 but it was a bunch.  Wouldn't complain if I could have that combine back though.  Also, how much would one of these cost a to buy when you get thru with it?  Or do I even want to know?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:18am
If you have to ask, you can't afford it!
Nice work Tom, getting real close.  That clean out is a great addition.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 8:08am
Well I eliminated two with that new fan bearing, and the replacement bearings for the pitman are sealed, so I guess 4 were eliminated.
If you need to ask you cant afford it.
Things I learned.....
Takes a ridiculous amount of man hours.  It would be cheaper to build a new clone-sort of. Every part would need to be drafted, prototype made, tooling made for the stamped parts...so you would need a lot of capital up front just to spec it out, then a lot of capital to buy the parts in quantities to get cost savings there.  The per unit cost would also go down with reduction of costs for rehabbing.
In conversations people start talking about making major mods to the machine...well that would jack the price.  Got to keep it simple stupid. Can do a few things...standarized bearings, bigger grain tank, but cant get carried away or you defeat the purpose of trying to make a easy to service simple machine. Also, the simplicity of the machine makes the parts simpler, and cheaper, to make.
The market would not be for your commodity farmers. Rather the under 100 acre specialty/organic/seed farmers who produce a high value product.  I have talked to a lot of these guys and they are begging for such a machine.  Problem is the size of market is hard to figure...hard to get capital/investors without such info.
A comparable machine is still made in Turkey and is 18K FOB Turkey.  Lot more sophisticated machine, but in  my mind, that is not necessarily a good thing. K.I.S.S.!
Given enough start up capital, I think one could be made for under $25K
I have no plans to do anymore except maybe for myself. Just takes too much time, and I couldnt do it for under 25K.  I would no longer be willing to pay myself  $0/hr for my labor.
Edited by TomYaz - 05 Feb 2012 at 8:09am
Regie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 4:20pm
Tom, is the metal on the back new or just cleaned up?
In your remarks about making a new machine, how much of the work could be done by a CNC machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:52pm
Thats new metal..
CNC could be heavily involved in making a lot of these bearings.  Most of them are cast and wouldnt want to make new ones that way.
You got some CNC capability?  There is a combination slip clutch/sprocket part that is high on my list...was told it would take a "three axis" CNC....would cost a fortune I bet.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 8:33pm
Great job done Tom. I spent many hours operating an AllCrop starting at 9 years old running an AllCrop 60 with bagger pulled by a WD with curved gear shift.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:03pm
My Dad had a MH Clipper...with tank..We just got to hang out in the pickup loaded with the oats and enjoyed the show...no work needed from us kids...maybe thats why it was one of my favorite farm "chores"
Tom
Edited by TomYaz - 05 Feb 2012 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:49pm
Tom is there a web site or at least a picture of the Turkish combine.  I'm sure I'm not the only one who would like to see it.
Is your allcrop customer as excited to see it finished as you are?
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:07pm
That looks fantastic. I can't begin to imagine the hours of labor and planning that are going into bringing that combine back to life! Your attention to detail is impressive. Please continue to keep us informed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:33am
The customer is in California; I have sent pics...not much comment.
