Cleaning up transmission WD-45
jzyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jzyta Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning up transmission WD-45
    Posted: 30 Nov 2009 at 8:40pm
Hi Guy's, what do you use to clean out that thick old oil/sludge in the bottom of the transmission and rear end?
Jim
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 8:48pm
Jim,  When we cleaned out the 140 oil from the B's to install a hyd we would take a gallon of kerosene and run it for a little bit then re drain it.
That was back in the 40's and 50's.  I know there must be much better stuff out there now.
Let's see what the others say.
Good Luck!
Bill Long
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 12:51am
You could pour some gas in there or get a gallon jug of Super Clean and do likewise, don't need to drown it just enough to thin it out til it flows easily. Let it sit for a few hours whatever you do and put the covers back on- Super Clean has a tendency to dry up if exposed and obviously gas will evaporate. You might have to stir up the sludge before draining to get it all.
Edited by Bill_MN - 01 Dec 2009 at 12:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:14am
I had that issue with my Oliver 60 when I put bearings in it's transmission. I have one of those small bench top parts washers. I set it on the floor under the drain hole and got a long piece of hose at the hardware store. Made it real easy to rinse and flush everything out that didn't belong in there. For solvent, I used mineral spirits.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:53am
I concur with Bill. Drain existing oil. Fill with kerosene and run it around for 20-30 minutes, then drain. Do not put it under load, just drive it around. HTH God Bless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jzyta Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 7:46pm
Hi Guy's, thanks for all the good advice!!
Jim
This page was generated in 0.043 seconds.
