Duals on a 185
Central WI AC guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Central WI AC guy Quote  Post ReplyReply Direct Link To This Post Topic: Duals on a 185
    Posted: 02 Dec 2011 at 2:47pm
Hi all! I have a 185 with 16.9-38s on it that I want to put duals on. It has the old style spin out clamps like a wd would have not the newer style like my 200 has, and I am wondering what/where I should attach the ring to where the clamp hooks up or if they make a special bracket for that type of spin out clamp. Thank you in advance, Jim
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 4:22pm
There are special brackets that clamp to the inside of the power-adjust rail.  There are two types; one is cast and has an eye for a J-bolt to hook into.  The other is more of a clip that sits inside the rail and keeps the hook seated to the rail.  Both styles work well and should be able to find used ones easily.
These are new ones from Unverferth (Brent Wagons).
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 10:31pm
 Just take the nuts off where your pieces attach the wheel to the rims. And put an eyebolt in place of the nuts. And attach your clamps there. That is how all the clamp on duals are around here.
                                                      IG
