D17 Carburetor
bincitybandit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Topic: D17 Carburetor
    Posted: 30 Nov 2011 at 4:10pm
Looking to get a new carburetor for a 1957 D17, S/N  10336.
Can anyone tell me the model # of the Zenith carburetor I would put on this tractor?  The number I can see on the brass stamp on top of the Carb is 12217.
Does it take the same carb as a WD45?
ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21
MINNEAPOLIS MOLINE: U, U, U(NF), GB
JOHN DEERE: L
FORD: 871 Select-O-Speed
CASE: 600 Combine
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 4:49pm
I've never seen a Zenith carb on a D-17, although I understand some came equipped with the Zenith Model 267 JB carburetor. Some WD-45s used a Zenith 267-8.
In any event, it appears that that number on the brass tag can be useful in obtaining the correct carb.
In my experience most WD-45s and D-17s appear to have been equipped with the Marvel-Schebler carburetors.
According to my A-C manual, some D-17s used the common Marvel-Schebler TSX-464 carb that was used on so many WD-45s, although they usually came with Marvel-Schebler  TSX-561, TSX-773 or (after Ser. #42001) TSX-871 carburetors. All of these carbs are listed in my parts manual as having also been used on the WD-45s.
You may have better luck finding one of the Marvel-Schebler carbs than a Zenith.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 5:40pm
           Are D17 has a Zenith on it since we had it but I can,t tell you which one because there is no tag. It is also a 1957 serial no. 2829.
                               John Carlson
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 5:54pm
i also have a zenith on my 57 d-17 s/n 3594. i too cant make out number on the brass tag.
6060 s\n 5016
1947 JD B
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 6:18pm
AND...my 1957 D17,serial #4128 also has the Zenith carb. on it and it came from the factory that way.  I've also seen the Zeniths on a lot of D17's...not uncommon at all.  Rick
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 6:33pm
All series I D17s i.e. prior to S/n 24001 used the Zenith Carburetor Model 267 J8
Still in use:
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:48pm
We Have new zenith carburetors #11588 for WD45 and D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 8:06pm
Well Rick, Maybe we should take a survey as to who's D17s have Zenith's vs Marvel-Scheblers? Uncommon, maybe not, common, maybe not either!
I didn't interpret the parts book as Orange Blood did; that ALL D-17s prior to Ser. #24001 were equipped with Zenith carbs. He may be correct!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 8:52pm
So, would a Zenith #11588 be a suitable replacement carburetor for my D17?
JOHN DEERE: L
CASE: 600 Combine
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 11:34pm
Here is a application link for Zenith Carburetors http://www.autotestsys.com/Zenith.htm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 11:41pm
Zenith Repl Carb # 14991
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 11:54pm
Brian...I don't care if they are common or uncommon really,I was just pointing out that I have a D17 with a Zenith carb. on it and that I've seen many of them like that and I have. I'm also sure that all of them didn't come here to central Mo. either! I think Clay pretty well cleared that up anyway with the info he supplied to the forum. Wasn't trying to ruffle any feathers and I hope you didn't take it that way.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 12:43am
Guys I am not trying to ruffle feathers either.  I simply posted information that comes right from Allis Chalmers documentation.  I do realize now, that I posted in an arogant fashion, posting answers without discussion or acknowleging others points.  I can't stand it when others do this, and I apologize, I am not a know it all, nor do I want to apear as such.
Anthony
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 8:20am
I appologize too!
I shouldn't have been so "sharp" with my post!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 8:26am
I did not see anything that should ruffle anyone's feathers.
(Perhaps the red print is a bit difficult to view compared to the black print.)
In my opinion, your comments were not political, confrontational or demeaning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 9:31am
Thanks a bunch for that info on the carb!
JOHN DEERE: L
CASE: 600 Combine
