Raincap for underhood muffler
waynem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Topic: Raincap for underhood muffler
    Posted: 22 Nov 2011 at 7:55am
Hi all I have a 1939 AC b with an underhood muffler. Does anyone know of a raincap to fit on the rectangular opening of the muffler? Thanks in advance Wayne
1939 Model B
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:06am
Cut the top out of these!!
You may try the rain cap of of a 6670 6680 or 6690 Agco. They have kinda of a rectangle outlet on the muffler.
RockyBottomFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:02pm
Can I get a pic of your muffler?
38 & 41 B, sickle mower, 2 way plows, rear field cultivator, 2 row drill planter
40 Combine
66 Combine
Roto Baler
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:20pm
I installed a raincap on my "C" with that muffler. I made the square outlet round by driving a piece of round stock or the right size deep well socket (check to see if it fits inlet first...they are the same size) into the outlet, then tap around the outside with a hammer to make it round and relieve it some to be able to pull out the round stock. Then put a standard rain cap on it.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:19pm
I did kinda the same thing cmsmoke mentions.
Hartland Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hartland Farm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:31pm
The reason the exhaust pipes are mashed to an oval on these tractors is to cause the proper back pressure on the engine. The way we run these tractors as collectors it doesn't make any differerence but to get the best preformance from any engine it must have the right amount of back pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:39pm
Still waiting for pic of muffler.....
40 Combine
66 Combine
Roto Baler
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:06pm
I am curious I always thought back pressure was a bad thing, no matter how little there was?  Can you help me understand how some is good?
Anthony
Still in use:
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:32pm
Rocky, go to the link for parts at the top of this page, and go to tony carbaughs site and look at the mufflers there.  you'll see a picture of the B underhood muffler there.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:50pm
Here's the one we run on our 38B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:12pm
Rocky I can't get a picture tonight but it looks just like the one Jim posted. I would like to keep the original rectangular shape of the muffler.
1939 Model B
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 10:05pm
The early B didn't have a muffler, they used a straight pipe. Prior to engine # BE43896.
The under hood muffler started with engine #bE43896 thru tractor # 114400. then they went to the thru the hood muffler.
Having the pipe pinched closed also will not let much rain enter the muffler.
Talking about back pressure, a friend of mine put 3" dual exhaust pipes on his Suburban and his gas mileage got worse then with the stock exhaust. Bob
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 3:11am
shucks...just put a soup can over it with a small chain or wire screwed into both...when ya start it, it'll blow off and stay until ya put it back on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 3:23am
Who needs a raincap on a tractor muffler? The wife's car sets outside and the B goes in the garage.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 4:20am
Right.
And if it's raining I don't run the tractors.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 5:21am
I don't believe making the outlet of the exhaust round hurts or changes the backpressure enough to worry about. The area of the opening is the same. The exhaust direction changes slightly outward into a fan shape when it is flattened. That is the place the backpressure would change, slightly. How many tractors were missing mufflers from the early start of life and still running strong today? Some didn't even have a muffler when they were new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 6:44am
Dan has a pretty good idea with the Black Pepper can. One of those would probably fit right over the end of the tube. I just cut the top off a plastic water bottle and place them over the pipes of the Tractors after they cool down. This way if I forget to take one off and start the Tractor and have "lift off", it doesn't hurt anything. Boy, they launch too! Don't ask me how I know that....  LOL!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 7:03am
As far as the pinched pipe relating to back pressure you may be right , I have had several WC's with the squashed pipe and noticed the noise is much less than with just a round pipe. Could this be the reason they pinched the end ?
