Switching engines between 185 and 200 |
Post Reply ![]() |
KevinON ![]() Orange Level ![]() Joined: 07 Dec 2009 Location: Schomberg, ON Points: 801 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Oct 2011 at 7:36am |
Are there any issues in switching motors from a 185 to a 200 as long as you add all of the external components of the 200 to the 185 block? Thanks!
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5105 |
only thing I can think of is 200 had crank driven oil pump, as did later 185's. so if 185 is early, I'm not sure how well 200 pan fits in 185 chassis. DR will chime in and set us all straight.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
From 185 to 200 will be no problem. If it was 200 into 180 the wish bone would be a problem but you should ok.
The only thing will be air cleaner pipe if you don't turbo it. MACK
I was thinking of taking an 185 with poor rear end and putting its motor into a 200 with a bad engine. I think that my 185 is a 1977 without checking the serial number.
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 956 |
Kevin - our 185 is turboed.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Reply ![]() |
