Wc wheel styles
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Topic: Wc wheel styles
    Posted: 03 Oct 2011 at 9:55pm
I am wondering if anyone truly knows what is supposed to be the wheel styles on a 1938 wc. Mine are currently spoked rears with a plain steel rim on the front. Does anyone know what they for sure should be? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:08pm
Stamped steel fronts are correct. I thought they switched to stamped steel rears some time in late 37 or early 38 but don't know how long a run those were. I can't find a picture right now either.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:18pm
1937 serial #59636 thru 1939 serial #81756 had one piece disc rear wheels so if yours is a 1938 it should have one piece disc wheels front and rear. Before these they were 24" spoked and after these they were 28" 2 piece with cast centers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:21pm
Here is an original unmolested tractor with the rims I mentioned.
If the picture don't come up, here is a direct link.
https://picasaweb.google.com/lh/photo/DR_n8KJ_1QDjIdVRUu5brw?feat=directlink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:25pm
Those are the ones that should be on a 1938.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:31pm
Ok that is a help. I recently learned my tractor started out on steel but then was converted sometime later so I was unsure what the correct rims were.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 10:45pm
CTucker, mine looks exactly like the wc picture 100 in the same album as you posted the link for
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2011 at 11:03pm
If yours originally had rear steel and was converted with cut offs then FLAT spokes would have been original. If it has round spokes then they are from an earlier tractor. Otherwise ALL 38s styled or unstyled would have the 24" pressed steel  rears and 16" 5 bolt (not 6 bolt) disc type fronts.
