WD45 Final Drive Question |
   Jeff(WD45-SATX-TN)
   Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443  |
      Quote   Reply
     Topic: WD45 Final Drive QuestionPosted: 02 Oct 2011 at 6:49pm  |
   I just replaced the bearings and bearing races in right side drive housing. Everything went in OK, got the seal seated, and the inner bearing on. Now, how much do you tighten the inner axel retaining bolt? The end play was out of it way before the bolt was even kind of tight. I snugged it down every thing still rotated fine. Just wondering how tight should I make it? I ordered a couple of 0.002" shims with the bearing kit. Should I use those?
  Jeff
     1954  WD45 NF  "Iron Tater"
   j.w.freck
   Joined: 16 Sep 2009 Location: karnack texas Points: 1153  |
      Quote   Reply
     Posted: 02 Oct 2011 at 8:44pm |
   jeff..according to my wd-45 ohm,you tighten down to a free rolling,no binding fit.i had one apart awhile back and it worked for me.just be certain you have no axial movement on the hub.sounds like you are doing fine....
   MACK
      Quote   Reply
     Posted: 02 Oct 2011 at 8:58pm |
   Tighten the bolt down tight with the shims under the washer. If there is inplay remove shims until all end play is gone. MACK
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
