Cleaning gas tank on WD 45
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning gas tank on WD 45
    Posted: 02 Sep 2011 at 9:18pm
Has any one had much luck with the do it yourself tank epoxy/cleaner kits?  My tank has had some fuel in it for about 7 years.  I was planning on pressure washing it out, but was told I should get it "steamed" at a rad shop - what is the steaming?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 9:25pm
A pressure washer won't hurt. Steam cleaning is just what it sounds like. Blow steam on it. Do you have rust in your tank or just varnish?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 9:55pm
I am going to put an inspection mirror in it tommorrow to find out.  thnaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 10:55pm
If it's old fuel residue, I've had good luck with the pour in the tank fuel injector cleaner. Let it set a day. The down side is you have to dispose of the liquidated crud. (waste oil barrell at work for me)
dpalmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpalmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 11:37pm
what i do is i took 2lbs of brass 5/16 bolts dump inside my tank and shake it till my arms feel like they are going to fall off (every direction including the tank jpside down) it will remove any rust or residue  plus your teflon liner will stick good
