WD45 Fill Plugs
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Fill Plugs
    Posted: 02 Sep 2011 at 9:16pm
I want to verify the location of the fill plugs.  I drained the hyd., trans and rear end and want to refill and flush.  Is the hyd. dip stick a filling location for the hyd?  There is one fill plug a few inches bag from the Hyd. fill plug - is this the tranny plug?  and there is one larger plug about half way back - is this the rear end plug?  Do I have this right?
I was planning on using hy-tran in the Hyd.  and 80-90 in the trans and rear end.  Could I use the hy-tran in the trans and rear end as well.
thanks,
Curtis
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 9:25pm
you are correct on the hydraulic fill. The 2 plugs to the rear are for the trans & rear which are 1 common space. I hope that you removed the drain plug on the bottom of the PTO housing. It is the lowest spot on th tranny. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 9:29pm
Yes to all. I put hy-tran in my 45 about 29 years ago. Some people say gear lube won't leak as fast. I don't have any trouble with leaks in my tranny or diff. I do have leaks in my hydraulic sump somewhere. A half quart a year hasn't made me get around to fixing it yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 9:44pm
Thanks - is there three plugs for the tranny rear end?  and one fill plug.
Is the dip stick for the hyd. also the fill or is the fill the plug a few inches back.
thnaks again.
I likely missed one of the trans/rear end drain plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 7:31am
3 drain plugs for differential and tranny and 2 fill plugs. There are 2 compartments but it won't run from one to the other fast enough to fill well.
 Yes, the dipstick is the fill hole for the hydraulics. Hydraulics has 1 drain and the dipstick fill hole.
 The plug just back of the hydraulic dipstick is the transmission fill plug.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 9:43am
There is also a 1/4" pipe plug at the bottom of the hydraulic control housing on the RH side of ther tractor. It is a good idea to drain the control on these old tractors as some "crud" can accumulate there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 9:44pm
Thanks for all the help.  I have found all the plugs.  The trans and axle plugs don't seem to thread back in very nicely.  Could they be cross threaded a bit?  The bind in spots when I thread them in.  I cleaned up the threads with a brush to get out all of the crud.
Or is this pipe thread which tightens up?  Or could I run a tap in the threads to clean them up?  the plug threads look good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 11:09pm
They are pipe thread and need to use pipe threaders to clean.Do not believe they were machined very good to start.
