Buying a 170
colsoncj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colsoncj Quote  Post ReplyReply Direct Link To This Post Topic: Buying a 170
    Posted: 24 Aug 2011 at 10:36pm
Looking at trading a truck for an Allis 170 diesel.  I dont know much about tractors, but I'm very mechanically inclined (Bachelor's in ME and starting building cars and now 4WD rockcrawlers over 10 years ago) and work on all my own stuff (or junk depending on who you ask).
Just like boats, campers, and cars I havent owned in the past, I know from experience there is a huge learning curve on what to look for, knowing whats a cheap fix, and what is a deal breaker.
I'm hoping to shorten that curve and get some solid advice on what I should be concerned with, look at, pay attention to, etc when looking at this Allis.
Thanks in advance for the help!
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 10:49pm
Check the power director to see if it snaps good into high and low.  That is the big lever on the right of transmission housing.  Check to see if the tranny pops out of any gears esp. 3 and 4.  Check front axle for wear etc. Everything else is just common sense such as engine noises, blow-by, brakes, power steering.  170 D are good tractors, uncle has got one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote colsoncj Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 6:04pm
Thanks for the heads up.  I assume by power director you're talking about the HI/LOW for the transmission, correct?
Anything else I should be on the watch out for, or any tests I should perform during the inspection.
I've been told raise the 3 pt up and stand on it to see if it drifts down.  Also lower the bucket all the way down and rotate, and it should pickup the front of the tractor.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 7:02pm
The powerdirector is the high/low range shift.  The one thing I would check is to try to drive it downhill in third gear and see if it stays in gear.  These tractors in my opinion are among the finest AC ever built.  They are like a D17 series 5, lots of years to get the bugs out of them, and they were.
This page was generated in 0.032 seconds.
