1948 wd distributor conversion
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: 1948 wd distributor conversion
    Posted: 30 Jul 2011 at 10:51pm
Please help. What do I need to convert from magneto to distributor ignition? I see the entire unit from a 45 or d17 that can be used, but I also see a bolt on with a "drive adapter". Which is it, or can it be both? Does any one have one or the other that I can buy? Help much appreciated, thanks, Trev.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 12:02am
Give Sandy Lake Implement a call monday.
I'm sure they can set you up.
1-888-252-0656
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 12:19am
We offer a complete Mag to Distributor conversion. Everything is rebuilt and ready to go. Distributor, Drive assy, all hardware. Choice of 6V or 12V coils, key switch, wiring, and wiring diagram. Available with optional electronic ignition also. Drop us a line if interested..
Steve@B&B    customcircuits@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 12:27am
Sorry Steve, I didn't think of you.
What are you doing up so late????
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 8:24am
I just helped a guy last month do a complete swap on a B. There was more to it than he originally thought. Most people forget about the oil lines and fittings to make it happen. Even the Governor cover had to be changed to go from a straight fitting to the tee fitting to allow lube to the distributor gear.
Going to the Delco distributor is an easier mod because it bolts to the mag drive thus uses the mag governor. I personally like that distributor better plus all the parts are automotive.
I'm sure Steve can do either one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 11:04am
Thanks to everyone who replied, I think i get it n ow. The simpler the better, I've always had good luck with Delco distributors. I'll use a Pertronix on it on 12 volt, as I have several others and they work great, really bring an old engine alive. I'll get a hold of Steve. I gotta figure out how to post pics of "Sweet Allis", Trev.
This page was generated in 0.106 seconds.
