Allis B
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Topic: Allis B
    Posted: 29 Jul 2011 at 10:51am
I have a B crank start. Wondering if low compression would make it not crank start but pull it 10ft. and will run. Checked compression and is 60lbs in all cylinders.Idon't think that is enough.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:28am
60 lbs is low. When checking compression did you open throttle wide open and disconnect air cleaner as well as have all plugs removed.. If you did, it would seem to me an overhaul is needed.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:29am
Check the impulse start mechanism in the magneto. Its there for hand cranking. If its not working, hand cranking won't work.
Gerald J.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:34am
Sounds like you need a stronger arm, LOL  good luck
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:36am
What Gerald said! you need to hear the impulse snap once every revolution of the crank.
It should start quite well at 60 pounds compression with some choke on.  It will not have the pulling power that low as it would at 90 or above.
