D14 information?
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Topic: D14 information?
    Posted: 28 Jul 2011 at 12:41pm
We brought a D14 home over the weekend, it looks pretty fair, but the engine is stuck. It will most likely take a while to get it running again. It is serial number 16782. It appears there were different paint schemes throughout production, so I am curious which scheme I should pursue when I get to that stage. Creme wheels? Orange wheels? Creme grill? Black grill? I have seen a lot of variations, so not sure what the "correct police" would recommend. Thank you!
Photo of D14
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 1:17pm
Only variation I know of is the black bar brill. The entire tractor was PO1. 1960 the D15 started the new PO2 paint scheme with creme wheels and such.
but I could be wrong.
Charlie
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 1:51pm
Looks pretty good just the way it sits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 2:22pm
Well.. it could use a wee bit of air in the right front tire......hehehe
My first( the '57) D-14 was stuck too. Every day I did the following faithfully..
1) try to rotate the crankshaft pulley with 1/2" drive  long bar.
2) if it didn't move, add ATF/diesel oil to every cyclinder through the plug holes
3) walk away until tomorrow...
repeated 1.2.3 until it moved just a bit...
then added more oil...walked away...
checked next day, moved it the opposite way...then more oil...walk away...
after 10 days I could slowly and carefully turn over the engine with what I thought was enough force..
added gas, battery... choke and away she went..been fine ever since.
be sure to pull the round hole on the bottom of the clutch housing and check for mouse house !! Mine was FULL ! Took 1/2 day to clean out !
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 2:50pm
The D14 never had cream grill or wheels (although I think they look better that way...I'm a big fan of the D15).  The '59 and '60 model years had the white and black block Allis-Chalmers sticker and silver and black grill.  The '57 and '58 years had grey Allis-Chalmers block letters, PO1 grill, and silver and PO1 wheels.
Edited by jtheise4 - 29 Jul 2011 at 1:12pm
1958 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 8:19pm
Thanks for the information. I also brought this Oliver 70 home. It is in pretty rough condition, I think I am going to have my hands full for a while!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 8:38pm
Looks as though you're all set for fun for a while! :)
WC, CA, D14, WD45
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 8:59pm
The 57 had silver letters, also 6 volt. The latter ones (59 & 60) were 12 volt and had the silver grille with black bars. decals on the hood were white with a black border.Wheels were always ogange PO1. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:40am
Thank you for all the responses. I wouldn't be surprised if I am back at a later date asking more questions!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 11:55am
Why don't you concentrate on the Oliver, and I will take that 14 off your hands real cheap!!  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 12:16pm
You are going to have to try harder than that! I didn't just fall off of the turnip truck, ya know!
Edited by redline - 29 Jul 2011 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 9:10am
I am a little unsure of the front wheel paint design. I get the impression that the center of rim should be PO#1 and the rim silver, is this correct? Should the silver be the aluminum silver that is generally accepted as correct for the rear rims? Thank you again!
Edited by redline - 30 Jul 2011 at 9:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:46am
Check out this video.  It is an Allis vintage movie about the D14 that will show you the correct colors.
1958 D14
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:56am
I have never seen a D14 with a creme grill, but I wonder if it didn't come that way though. The tractor doesn't appear to have been repainted from the picture.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 3:37pm
You have a 59 model year. Swinford's book shows the D14 thru sn 18230 was all P.O. #1. The only silver ever used was on the rims and muffler. The wheel centers were originally orange. The black bar grilles started at sn 19001.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 11:50pm
Thank you. Now it is starting to make sense to me. I just couldn't see how the grille on mine could have black bars on silver mesh, when there weren't any bars. The serial number break makes it logical. Do I still need the black/white decals? I prefer the looks of the silver letters and the D14 in the circle on side panel. As you can see, I have plenty of time to figure this stuff out, but it is on my mind now. Thanks!
