LOADER FOR 1947 C ????????
DKB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DKB Quote  Post ReplyReply Direct Link To This Post Topic: LOADER FOR 1947 C ????????
    Posted: 25 Jul 2011 at 10:56pm
I just bought  my first  Allis Chalmers a 1947 C model.   Anything special I need to know.  Also, can anyone tell me if a loader attachment is available.
Edited by DKB - 26 Jul 2011 at 12:33pm
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 8:32am
Henderson made a loader for the B, C, and CA. They used a Char lyn pump that ran off the PTO.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 9:12am
A Allis modle 100 will also fit a C. The one I put on My CA came off a C. While it works good. I would not put a loader on a C. It's a nice light nimlbe tractor untill you add a loader. then it becomes a clumbersome hard to steer front heavy beast.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:14pm
Horn also made a loader for the B/C tractors, they also private labeled it for New Idea. Dad sold one of the New Idea versions at a GOTO a couple of years ago. Keep looking they do show up for sale. Kip
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:25pm
Most if not all antque tractors where not designed for front end loaders. Adding them on is to overload the front axles and steering with little capability anyhow.
DKB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DKB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:31pm
Thanks for your input!!!!!  I would like to be able to move things around the farm, at least round bales any ideas.  Also new question.....needs an oil change ..what oil do I use ??  I don't need non detergent do I?  My old Ford takes the non.
Also I just hooked up the front blade  but it doesn't lift very high only about 6 inches off the ground is that normal??
Edited by DKB - 26 Jul 2011 at 12:37pm
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 1:04pm
I use 10w30 in mine and I have never had a problem. You don't need non-detergent, unless that is your preference.
Do you have 7 quarts of fluid in the transmission? The Hydraulics work off the oil in the transmission and there is a baffle/dam that the 'extra' portion of the oil sits to run the hydraulic pump. As others have said, these tractors weren't really made to have loaders on them. Usually if they have loaders, they have 2 rams and/or a belt driven aftermarket hydraulic pump.
And Welcome to the Forum! Everything you could ever need to know about these tractors can be found here!
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 1:57pm
Would be nice to see a pic of your new darling if you can. I would like to see one with the front blade and welcome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 2:31pm
I have a Henderson loader on the front of my B model. The ole' girl does steer a bit harder, but being its a wide front, it seems to handle the loader okay. I could see where a loader on a NF C Model could be a problem. I use my loader around the property for dirt, gravel, and keeping the compost pile back a bit, but it does come in handy! I'll even pick up and move a small engine once in a while. As for oil, I've been using 10w40 for years without any troubles in all my machines and equipment.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 6:14pm
They would have to be very small round bales to pick up with a C. I built a lift for the back of my C that worked very well. I went straight up from the ball hitch to above my head with a piece of 2" well pipe. than just had angle Iron  lift beam about 3' long ata the top braced back to the pole. it only took about a minute tio install just slip over the Ball hitch and use a twisted clevise around the pipe and rock shaft. lift was a manual winch worked real well. I gave it away before I thought about getting a picture.
DKB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DKB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 5:48am
Do you have 7 quarts of fluid in the transmission? I HAVEN'T CHECKED YET BUT WOULD ASSUME IT'S FULL SINCE THE PRIOR OWNER, (WHOM  DECEASED 5 YRS AGO), TOOK EXCELLENT CARE OF HIS A-C.  IS THERE ANY WAY  THE FLUID COULD HAVE ESCAPED?  i DON'T SEE A LEAK ANYWHERE. The Hydraulics work off the oil in the transmission and there is a baffle/dam that the 'extra' portion of the oil sits to run the hydraulic pump. As others have said, these tractors weren't really made to have loaders on them. Usually if they have loaders, they have 2 rams and/or a belt driven aftermarket hydraulic pump.
Edited by DKB - 27 Jul 2011 at 5:51am
DKB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DKB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 5:59am
Thanks all I like this forum already.   Hope I can get this blade problem figured out soon.  I was using it yesterday pushing dirt/manure/compost and it's getting old with the blade not working properly.  Is there a setting or something  I'm missing
