WC idle issues
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Topic: WC idle issues
    Posted: 25 Jun 2011 at 10:36pm
Having problems getting my 38 wc to run. I have thoroughly cleaned and worked over the carb. I backed out the fuel needle and the idle screw out 1.5 turns to start out. It will idle fine on choke, but will die as soon as the choke is shut off. Lookin for some help. thanks
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 10:39pm
Some of the small Venturi's are plugged up in the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 10:45pm
have you had this problem before?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 10:48pm
Yes, It can be very agravating, Take your time and clean every orfice inside the carb and blow air through
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 10:55pm
Yes your right it can be. Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 8:19am
It could be sucking air somewhere. Try spraying WD40 or some other combustible around the intake manifold without the choke on. If you hear a change in the engine rpm, you have a leak.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 9:05am
good luck!
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
