coal sandblasting
blidtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blidtke Quote  Post ReplyReply Direct Link To This Post Topic: coal sandblasting
    Posted: 24 Jun 2011 at 9:48pm
watching american restoration anybody use coal chips to blast parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:58pm
what they use is coal sl*g, what is left after it is ground up and blown into boilers m you get sl*g, and fly-ash in the firebox, the sl*g is graded and used for blast material and for roofing shingle grit. ,
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 1:02am
Commonly known as "Black Beauty" or "Black Diamond".
Tractor Supply and Northern Tool carry 50# bags of Black Diamond for $7.99/bag.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 6:23am
Its being used for OSHA and EPA reasons. I hate the stuff. Pits the metal bad. Silica sand does way better job. BB is ok for semi trailers and the such but not our sensitive sheetmetal parts on tractors hehehhe.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:22am
Plus premium playground sand only costs @3$ /50lbs.  Breaks the clay up in my back yard also.
Soda would be the way to go if it wasn't so expensive.  Rain just dissolves it!
Bob, North Carolina
1949 B
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:26am
It's fine for aggressive blasting, but for most tractor restoration work, garnet works the best, not much more than sand cost-wise, much safer, and cuts faster with similar finish results.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 9:12am
I agree with the garnet.
1954 WD45 NF "Iron Tater"
