Water temp on D19 diesel
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Water temp on D19 diesel
    Posted: 24 Jun 2011 at 8:41pm
Hi guys,
I have a D19 that I just overhauled that doesn't get over 170F.  I checked this with two temp gauges.  I pulled the thermostat and it is a 160F unit
Should I put a hotter thermostat in?  What temp should I use?
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 12:06am
My D19 diesel very rarely gets the temp gauge over 170 or in the green run zone. When i go plowing it the runs about 180 and cools off rather quickly. The only time that it was over 170 and i was driving it around and not working it was about 3 weeks ago when it was over a 100 in the shade. I have 180 degree thermostat in it.   Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:00am
I have a 180 thermostat in my D17D. That puts the needle on the gauge right about the middle of the green zone. I haven't had the chance to put any real load on it to know how it would react. It did have a 160 thermostat in it when I pulled it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 5:54am
Thanks guys.  I dropped in a 180F and now it runs a little to the left of mid-green.  Just thought putting in a hotter thermostat may help the thing run cleaner.
Terry
This page was generated in 0.172 seconds.
