AC Plugs
Rich Steiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Topic: AC Plugs
    Posted: 03 May 2011 at 7:07am
I see a lot of information about spark plugs on here.
I have been using Champion, but I want to try AC.  So I went to my Tractor Supply store and they had Autolite 295 plugs.  On the back of the box it says that they are good for "B, C, CA, G, 1B, RC, S, WC, WD, and so on.
Sounds like these are the same as AC45's right?
Any comments?
Rich
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:28am
I'm happy with the Autolite 295 plugs. Don't know about the AC-45's. Never used them.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:34am
Thanks for the reply.....
Rich
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:36am
I use Autolite 295, they have been a good plug for me.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:36am
Yup,295;s!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:44am
You can`t get plain AC 45`s, they only have the resister type (AC45R).
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:01am
I've had problems with the Autolite's too and have gone back to Champions.  I think it is the s--t gas we get now and not so much the plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:08am
You might have something there Ted. Several years ago my Dad put new plugs in his old Ford pick up. He evidently flooded it trying to start it. After "fixing"everything else we thought could be wrong with it, we found out the plugs were varnished over and causing the rough running problem.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 11:48am
Burgie, I have AC Delco R45S plugs in my WD45. Would that be a restistor type plug?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 11:53am
R in the R45 means resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:02pm
Brian, thats what I was thinking. Ive always had good luck with them. I use AC Delco plugs on every gas motor I have. Ive never had good luck with Champion and have never tried Autolite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:06pm
My personal experience is Champion plugs are better at being used as a fishing sinker than as a spark plug in an engine.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 2:48pm
What were the factory plugs for a WD? I know the manuals, etc. always list different plugs and there are different cross-reference numbers. Did they use more than one type of plug or was there a single original type?
WEL(IN&TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(IN&TN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 2:51pm
I have used Champion, AC and Autolite in most of my AC tractors. The Autolite 295 is the hands down winner but the ACs are also good. The Champion plugs are junk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 2:54pm
Champion J-8
Put like someone said Champion took a noise dive in quality. I haven't used them in a long time.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 3:12pm
Yes champions are crap these days, use either AC or Autolite now. I was just curious what they used back then, I'm sure Champion was tops back in the 50s
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 3:30pm
Keep an eye out for AC45XL on Ebay and other auction sites.  On occasion N.O.S. AC45XL plugs are offered.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 3:56pm
AC45XL   What does the "XL" stand for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 4:01pm
That is the long reach plugs.
"Burgie"
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 4:06pm
Aren't AC45XL 3/4" reach for the late D17, I thought XL ment extra long?
I'm not sure if Champions were ever any good, we always used AC or Autolites. Dad used to say Champion didn't make sparkplugs they made trouble.
Edited by Dave in il - 03 May 2011 at 4:07pm
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:20pm
Autolite Double Platinum Spark Plug
Part No. 295DP Warranty
 Are double platinum ok to use in a WD45?
Edited by dannyraddatz - 03 May 2011 at 7:21pm
Danny Raddatz
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:32pm
^^Made me think about some platinum plugs.
Unrelated to tractors but Jeep uses champion in a lot of their motors.. Just the regular copper plus plugs. Changed the plugs in a 2004 Jeep with 90k miles and not sure if they have been replaced before or not. They recommend replacement at 30k miles. The plugs were the worst I've ever seen for wear. The electrode was completely rounded and the gap had really increased. For 1.10 more than the copper plugs we got got autolite platinum ($3.49).
Many OEM plugs are good for 100k miles. If the tractor was tuned well, wouldn't iridium plugs outlive the engine?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:14pm
If I recall the new Allis Chalmers units we sold from 1935 - 1962 were delivered with Auto Light and Delco plugs.  At that time span when we replaced plugs we preferred the Delco AC-45.  As the engines began to wear and use oil we replaced with hotter plugs AC 47 and AC 48's
In fact we found at that time that the Auto Light plugs were inferior in performance to the AC's.  At times we replaced original equipment Auto Lite with AC's to improve perfromance.
That was some 49 years ago.  The reports I have heard on this site indicate that the preferred plug now is the Auto Light.  In fact, my Good Friend Steve NJ Custom Ciircuits highly recommends Auto Lite.
Hope this is some help.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 7:24am
Thanks so much for all your replies......
I'll let you know how I make out if it ever stops raining around here
Rich
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:44am
I always use autolite 303's, never a bit of trouble with them.  I will not even lay hands on a champion, but don't mind AC delco's either.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:09am
I've got some Allis Chalmers plugs. They have the Allis  logo on them and the number 9001653.  They look like an AC plug otherwise. Anyone know if AC made these plugs for Allis?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 12:08pm
Here is a page to do conversions from one plug to other brands ..
Also gives the reach and type of tip on plug and gasket .
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 5:10pm
I have not had any luck with Champion plugs. And i have never had a problem with AC  plugs if the engine is not pumping oil. If the engine is pumping oil none of them will last. I have run Autolite plugs in my trucks with no problem.
The universal answer to all questions is yes, how much do you want to spend?
