Engine break-in period
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Topic: Engine break-in period
    Posted: 25 Apr 2011 at 10:28am
I have a 1938 B that I am buying that has less that 2 hours on a complete rebuild. The only things that are not new are the block and the head, though they have been reground. The two hours were used to set timing/magneto and make sure it runs properly. everything else in the tractor has been replaced/rebuilt also, front to back. All it really needs is paint as it is original.
I am planning on using this tractor, and I was wondering what special care I need to take in the Break-in period so it will last another 70 years, assuming I can buy gas for it! LOL
Thanks,
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:52am
At 2 hours it is already past the critcal period.  First time you have it warmed up change the oil to get rid of assembly and break in particles. Most instructions will tell you to not run it wide open for hours and dont let it sit and idle other than that just use it. Far too many error on the side of pussy footing around hour after hour with a new overhaul and its realy not the best thing to do with a new engine IMO.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 11:11am
Put her to work,just watch oil pressure and water temp,and what Butch said.
