Which One?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: Which One?
    Posted: 20 Apr 2011 at 11:30am
Picked up a 7000 Special and a 7010.  Hope to make one from the two.  Not much history on either.  7010 has a rod thru the block.  Which one should it be?  Dale
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:36am
The 7010 has an updated rearend and trans. If the 7000 has a good motor id just swap the motor and have a good 7010.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:40am
I will be the ginea pig What is a 7000 "special"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:45am
Dale - maybe Hurst will buy some spare parts off the 7000 Special for his.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 12:02pm
7000 special has heavy front axle like a 7010 and up. I think they were all black chassis tractors.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 12:29pm
The 7000 Special came out AFTER the release of the 7010/7020.  AC was getting all the remaining 7000 parts used up.   The Special part was there were no options, it came with cab, A/C, heavy front end, and big tires, you could not substiute or deduct any options, there also was a small price break to get them sold.   I did sell a couple of them, and they worked out OK.    HTH
