Unknown Allis-Chalmers Part
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Unknown Allis-Chalmers Part
    Posted: 25 Mar 2011 at 11:17pm
The following item is listed on eBay.  The part number is 249977.  The auction description indicates these bearings fit the B, IB & G tractors.
I looked for this part number in my Model G Dealer Parts Manual but it isn't listed in the index.  I also looked for this part number in my B, IB C Dealer Parts manual but again it wasn't listed.  However, this part number is in my Allis-Chalmers Master Parts Index and it is listed as a Bearing for the B, IB & G tractors.
While there are parts common to the B, IB & G tractors (transmission comes to mind) usually the model C is also included.  The only place I've found that has common parts for ONLY the B, IB & G is the Steering Gear Box.  Yet there isn't anything that looks like the picture of the part there.
I can't figure out where these bearings would go on a Model G...  any thoughts?
Scott
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:45am
Steering box bearings.
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 7:34am
Yes Fred they are steering box bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:17am
My Model G Dealer Parts Manual has "Worm Bearing Cup" [Part # 210467] Quantity 2 & "Worm Bearing Ball" [Part # 915904] Quantity 20.
The "Worm Bearing Ball" [Part # 915904] is described in the Standard Parts Manual as "Grade No. 3 Chrome Steel" "Size 5/16".
So I guess the auction item was an "engineering upgrade" that would replace the loose bearing balls in the original steering box with fewer balls as a result of the "ball holder" design of the upgrade.
Best regards,
Scott
allisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 11:34am
they look like the bearings in a d14 power steering pump
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:10pm
They look like the parts I got from AGCO when I rebuilt the Ross steering box. Fred and Mark know their parts.
