Hydro pump rattle
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Hydro pump rattle
    Posted: 06 Jan 2011 at 6:33pm
Curious as to what would cause the hydraulic  pump on a WD45 to rattle when the hydraulics are in use? It started in '03 when we put the loader back on after we got new (used) loader arms when we first topped off the oil the pump for the loader. at least that's when I first noticed it but I was 10 or 11 then and don't remember hearing it before that. Is it normal? is there a simple fix?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 6:57pm
Don't know what you mean by "rattle".The thumb screw on the front all the way out against the housing?That will make em squeal and slower if not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:09pm
this is not my tractor, but watch the whole video and you shall hear it when he raises the 3pt.
[TUBE]ZGgGIJ8XDjY[/TUBE]
German Shepherd dad
#WD234847
#WD88193
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:41pm
Sounds exactly like mine, and every one I have ever used.  I think it is only because it is a four plunger pump, and at idle, you have a very distinctive pulse from each plunger.
Still in use:
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:35pm
All of mine do it too so it is either normal or a problem that does not get worse or effect anything
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 11:29pm
That is normal. It's more of a knock than a rattle. The heavier the load,the louder it will be.
Edited by Steve M C/IL - 06 Jan 2011 at 11:31pm
This page was generated in 0.150 seconds.
