B hydraulic cylinder I put this in the wrong spot
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: B hydraulic cylinder I put this in the wrong spot
    Posted: 18 Sep 2026 at 8:04pm
It is jumping when I lift my 59 mower. Even after cycling 4 or 5 times. I use 30 wt motor oil. Could one of the pistons be stuck in?   I don’t really use it all that much so it’s not a big deal. I need to replace the gasket on the shifter plate after mowing is over so since I have to drain the oil, I will pull the pump to.
Opps I put this in the wrong forum.
Edited by john2189 - 18 Sep 2026 at 8:08pm
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2026 at 9:54pm
when the cylinder packing leaks, they TIGHTEN the nut and compress the packing.. When the packing gets old and hard as a rock, and you TIGHTEN it more, it will drag BAD..
If you dont have new packing in the last few years, i would try that.....as a test,  loosen the head nut and let it leak, and try it to see if the JUMPING goes away
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 6:17am
Thanks. I will try that
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2026 at 7:16am
The B & C tractors only have 2 plungers and even when all is working correctly you will notice a minor jerkyness.
  You tractor operators manual calls for 20wt or in colder weather 10wt. Try draining the 30wt and use UTF.
