FEL bucket curl?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: FEL bucket curl?
    Posted: 31 Jul 2026 at 9:15am
On a FEL, does the bucket need a stop, or does the end travel of curl cylinder stop it? Seems like a stop if before end travel of cylinder, would bind or twist frame. Thanks, Tracy
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2026 at 9:18am
My Ford TLB has a stop just before end of travel
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2026 at 9:37am
Really do not want Cylinder Internals to Hard Stop Curl or Dump, not only to prevent component damage but to allow port access on Side of Cylinder for oil entry avoiding Seals Position around piston.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2026 at 11:35am
I have known of people pulling the glands out of bucket cylinder on loaders like the JD 145/148 loaders using the dumped bucket as a dozer blade, when the buckets did not have proper dump side hard stops.  hard stops should come into play a bit before the end of cylinder travel.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2026 at 9:59pm
I don't remember having seen bucket tilt stops on loaders on farm tractors or any of the mid size skid-loaders. Although, some of the newer larger skid loaders and loaders on 150+ hp farm tractors made in last few years may now be using them.
 When you get into the articulated type construction loaders most have a physical stop built into the bucket tilt linkages. The mid size Case with 2 bucket tilt cylinders are the exception and have no mechanical stops.
