7040 axle duals
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Topic: 7040 axle duals
    Posted: 09 Jul 2026 at 10:16am
What options do I have on a 7040 with a short axle to run duals to straddle corn on 30" rows?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 10:51am
Mexican hat with spin out
rim wound probaly do it if theres enough room on the axle to mount it. If there is enough room on the axle a 10 bolt hub with a spacer between it and the wheel
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 1:33pm
Flower pot hubs may be easier to find, then you can use the more readily available 9 bolt pressed steel dual rims, many have a deep enough offset to get out to the 120".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 1:46pm
Thanks guys, I dind't think the axles would be long enough to just but on a hub. There's tractor for same that I was mildly thinking about but I require it to run down 30" rows with duals
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 1:58pm
I had hub duals on 7030 with short axle.  Not set for 30 inch rows but enough room for the hub.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 3:35pm
I have an 8050 with short axles with 10 bolt DMI hubs on it. About 3/4 of an inch of the hub sticks out past the axle. I've had them on there for at least 10 years and have not had a bit of trouble. I also have and 8070 short axle with 9 bolt hubs, three u-bolts and the hub is also about three quarters of an inch past the end of the axle. Again those duals have been on that tractor 10 years or better. DMI also makes 4-in or 8 in spacers for 10 bolt to get out to a 30 inch row spacing. On the 8050 with the 10 bolt DMI hubs if I had a 4-in spacer it would be perfect for 30-in rows.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2026 at 5:00pm
Unverferth makes the hubs and spacers. I think wold makes them also
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 10:34pm
My 8030 short axle has 10 bolt hub duals and spaced nice for 30in rows. Axle is recessed in hub about 3/4in. Suppose it depends on how much dish is in dual wheel. Bought it this way.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 1:15pm
Guess not what you’re looking for and don’t know your location…. I have T-Rail clamp on duals that are for 30 inch rows. They are for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 1:23pm
Clamp on doesn't play well with 2ft tall corn....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 1:33pm
K. Like I said, not what you were looking for.
