wanted Wd45 & C parts |
BILLP-SE-MI
Joined: 13 Sep 2009 Location: SE Michigan Points: 698 |
Topic: wanted Wd45 & C partsPosted: 25 Jun 2026 at 8:08pm |
Will be at Penfield GOTO on Sat. WD45 4 bolt wide front Bolster . just bolster not complete front end. casting between frame rails. very nice C grill. 3 hole or 5 hole pan seat. no welds Steel wheeled C or B, tall pipe air cleaner. Also looking for a CA Hydraulic pump delete cover Pt # 225195 for covering the Hyd opening. Cover on it's way** Thanks Paul B (Just added.) C draw bar brackets, Ca snap coupler release lever. WC brake lever extension clamps.4 needed. Thanks Bill P. send a PM. or Text. 734+347+5426
Edited by BILLP-SE-MI - 05 Jul 2026 at 8:35pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5435 |
Posted: 25 Jun 2026 at 8:16pm |
I won't be a Penfield, However if you don't find the CA hydraulic pump delete I have a few.
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1029 |
Posted: 25 Jun 2026 at 9:48pm |
have 4 bolt steering block
BILLP-SE-MI
Posted: 26 Jun 2026 at 10:33am |
sent PM
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1385 |
Posted: 26 Jun 2026 at 6:13pm |
I should have front end also
