Turbo WF
NextGenAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NextGenAllis Quote  Post ReplyReply Direct Link To This Post Topic: Turbo WF
    Posted: 06 Feb 2023 at 11:27am
Question if anyone has ever put a turbo on a WF. I have one from work off a yanmar diesel. Small Turbo. The machine it came off of is getting a new one cause the old one i have is "locked up" and the seals are bad. There is no core charge on it, so i was going to keep it and rebuild it and hopefully throw it on my WF as a fun little project!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 3:37pm
Anything is possible with enough time and money.  You would have to build a completely new manifold to accommodate it.  The low oil pressure system in the WF might be a problem keeping the turbo properly lubricated and cool.  Sounds like a lot of work for little reward.  If you want a turbo on your WF, Keystone builds a kit that is pretty much bolt on.  In your case, you would have to make everything from scratch.
Personally, I could spend my time and money on other projects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 3:44pm
I think the lack of adequate oil pressure would be my main concern..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 9:41pm
Turbos have a orffice to limit the amount of oil.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:36am
 From My personal experience I'd be concerned about the weakness of the bottom of the block at increased power. I've seen more than a few of the 226 blocks with the main caps shattered and the supporting areas of the block destroyed. As Mack said , even though turbos need to be oiled, the smaller ones don't use muck. Were I to turbo a 201/226 block I would refit it for a full flow filter system and build in some added support for the crankshaft mains.
 Now if you just want a toy that has a whistle without performance get a Keystone kit and have fun.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:39am
I'd call it Turbo WTF, or Turbo t**d. Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 7:12am
PaulB is correct, much power and it will pull the main webbing out of block. Been there.                      MACK
