7050 powerdirector rebuild question
notime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Topic: 7050 powerdirector rebuild question
    Posted: 15 Nov 2022 at 2:02pm
Hi
My hi range piston and separator plate are scored. Can the piston be resurfaced?
Any comments are appreciated.
Thanks
Edited by notime - 15 Nov 2022 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 8:34pm
The piston should be ok cause a it lays again a hold plate. The separator plate should be replaced if it is warped.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2022 at 9:46pm
Thanks Mack. So the matting surfaces of the piston and separator plate don’t need to be smooth? I guess it is different than a clutch to flywheel arrangement.
