Agco Alllis 5670 - good or bad?
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Topic: Agco Alllis 5670 - good or bad?
    Posted: 05 Jul 2022 at 5:09pm
Good afternoon, folks;
Got a chance to buy a 5670 from a friend of mine.  Any good or bad to know about these tractors?  This one has 1800 original hours and in good shape.  It has sat for a couple of years, but I did start it about a week ago.  Put a good battery in and it fired right up, engine probably didn't turn over three times.
The oil is good and black.  Runs good, the three point lift operates well, (haven't had it hooked to anything to test the remotes), and the PTO spins.  Original decent tires all the way around. Two wheel drive.
I know they're air cooled, which I like - we have a Deutz Allis 6260 that my grandpa bought new that now has almost 10,000 hours that has been great.
If anyone has one, had one, or has any experience with one, I'd appreciate your recommendations for or against.  I won't use it for much, maybe a little bush hogging, feeding some hay, raking or teddering hay, stuff like that.
Thanks!
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
Ricky D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky D Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 7:55pm
We've had one, 4 x 4, for 4 or 5 yrs, with loader. Had done a lot of loader work so shuttle "sometimes" jumps out and "sometimes" out of 2nd. We use it mostly for loader work so like the 4 x 4, starts good except when real cold cuz doesn't have decent engine heater (air cooled), easy on fuel. Syncro trans shifts nice. 2500 hr ????
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 7:23am
We have had one since 2000 when bought new with agco loader.  It's 2wd and it starts right up in winter and it does have the heater.  It is the primary loader tractor.  The only major complaint about it is the remotes operation with the levers behind the seat, but since the loader has a joystick and we don't use the remotes much otherwise not too big of deal.  Over 4k hrs, maybe 5K now(can't remember), and we have only had to change the clutch once.
