Anhydrous tank running gears
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: Anhydrous tank running gears
    Posted: 27 Oct 2021 at 9:55pm
Has anyone put a wide platform on the 5th wheel steer?  Have a nice one with good tires and want to make use of the tires...Have one under a nurse tank and that works well...Thanks...Dale
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 5:46am
I've seen a few made into hay racks.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 9:18am
AaronSEIA
   my original thought was a thrower wagon but I was told a flat but not as high as a  bale kicker rack....Thanks for the response....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 6:29pm
I've put an old truck flatbed on a 5th wheel wagon: I use it to go get wood pellets and then I don't have to unload them until I need them. It trails great behind the pick-up and is easy to back as well.
  My rims are just the standard 5 bolt AG pattern. Yours are probably the standard 5 or 6 bolt Ag pattern and would interchange with other wagons.
  The 5th wheel gear will have a higher deck height than an auto-steer gear.
