Gleaner K2 setup for alsyke clover
grgry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grgry Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner K2 setup for alsyke clover
    Posted: 08 Aug 2021 at 8:10pm
Newbie on the farm. Want to harvest clover seed using a Gleaner K2, what do I need and what would be starting setup. I'll most probably need to be walked around as it's very new to me...don't know the lingo nor the operation yet....
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 8:30pm
Welcome to the AC forum. I hope someone will come on and help you. Good question to ask and no question is too stupid to ask!
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 8:34pm
I did a google search and found this post and several people mention the K.
click here for link to post
Post Options Post Options   Thanks (0) Thanks(0)   Quote grgry Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 9:35pm
Hi Mike  Thanks for the welcome and the link.
Hoping to make use of others experience and lower the learning curve...
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 10:00pm
grgry, welcome to the AC forum. This picture will help identify different older gleaner components for you. It says F2, but K2 is basically the same layout, but K2 has one less straw walker in width.
If you have an Operator’s Manual for your K2, start reading it. It will explain many necessary operations, setups, & servicing for it. AllisChalmerGuy’s link is a great start too. In it, carefully study Tbran’s good advice. Pay special attention to his FAN ADVISE.
Please share some about your K2
- gas or diesel?
- serial number(located on ID plate on rear left under engine ladder)?
- platform size 10’,12’,13’,15’????
-Unloading auger-manual or hydraulic swing out?
Edited by AC7060IL - 10 Aug 2021 at 6:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote grgry Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2021 at 9:27pm
Hi AC7060IL
Thanks for the graphic. I don't have the machine on hand for the serial #
It's a gas operated machine and would guesstimate the platform to 12 ft maybe 10, it's a little wider than the machine itself.
Don't know what type of auger. Just bought the machine about 20 miles away and still need to go and get it.
Plan to do eventually up to 30 acres of Alsike clover and 15 acres of phacilia.
Got into beekeeping and trying to vertically incorporate the whole process from the flowers, bees and queen raising to the extraction of honey.  Crazy retirement project..
Once again thanks...
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2021 at 3:50am
Hi are you going to use a Draper front or are you going to direct harvest I have found direct harvesting the best but your paddocks need to be like a bowling green the drum needs to be fast and tight I use a 3mm set riddle in the top and check for leaks .this works on the massy 400 and New Holland 1540 / TF 42 I use to run. Best of luck
Tractors Allis EB,two C,diesel G
Post Options Post Options   Thanks (0) Thanks(0)   Quote grgry Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2021 at 11:28am
Hi Kiwi, Thanks for the return, I do have a draper on the front. The field is far from a bowling alley even though we removed tons of rocks. And it's on an rolling incline.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2021 at 9:31pm
I’m not familiar with that type of clover but we regularly combine red clover. My combine settings are as follows.
Adjust the cylinder down with thrasher engaged at idle until you hear the cylinder tapping the concaves. Adjust up until clicking stops and tighten it down. That’s a good time to zero your cylinder clearance scale.
Fan at 2. Catch a handful of chaff coming on the back of the shoe whit friend driving and look for clover seed blowing over. Adjust fan slightly up or down to clean sample or eliminate blowing over.
Solid grain pan installed below sieve to direct clover into clean grain.
Top sieve open around 3/8”. This is the one I’m having the most trouble remembering. If you find your overloading tailings to get a clean sample you may have to tighten this down a little.
Bottom sieve open around 1/4. Close until sample cleans up.
We spray to kill the plants so it’s all dry going in the machine and cut standing crop. If you don’t want to spray you will have to cut it with a sickle mower and rake early with dew on and pick up the windrows. We used to do it that way when I was a kid and had greater loss.
Good luck and I hope I helped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grgry Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 11:37am
Thanks Wekracer. It gives me a starting point. Looking at # of seeds per pound, it would appear that the white clover is 1/3 the size of the red clover (728k vs 272K for red). once again thanks..
