hydraulic rebuild kit?
teetime74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teetime74 Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic rebuild kit?
    Posted: 11 Sep 2010 at 10:47am
does anyone have a link for a rebuild kit for a d10 hydraulic pump
Jim Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Blue Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2010 at 1:53pm
Kits are not available.  You will need to order seals and o-rings by part number.  Hard parts are not available for the control valve so I doubt they are available for the pump.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2010 at 2:19pm
If the pump is the same as a ca I have a complete parts list with prices for a rebuild that I could send you. Ron
CA Tractor
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2010 at 5:43pm
  which pump are you looking   we have the rear pumps  for series 2&3  also hve some new gears as needed   1-574-342-4545 for more info. have repaired some  also you do not tell what is needed???????    which pump??/
Post Options Post Options   Thanks (0) Thanks(0)   Quote teetime74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:19am
send me the parts list for the ca thanks that will help alot it is a plunger type hydraulic pump all i seem to find is a gear driven online thanks for the help
