gear reduction stater
dakotawc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dakotawc Quote  Post ReplyReply Direct Link To This Post Topic: gear reduction stater
    Posted: 20 Oct 2020 at 1:01pm
Should I repair or replace the starter on my 8070? Drive won't stay engaged now with the cold weather. Any comments on replacement gear reduction starters , good or bad? Where did you purchase yours? Thanks for your input. This site is the BEST!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 3:07pm
If the rest of the starter is good you can replace or clean the starter drive.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 6:08pm
Do a search on Google for 7000 series gear reduction starter. I did this to a 7060 and it may help you. Can't get it to pull up here for some reason.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 7:52pm
I recently done one on a 6080 with a newer high torque and thats the way to go, the rebuild on an old style is 3/4 the price of the new one- just my expirence,
Joe(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 7:53pm
Just put a new gear reduction one on two days ago from carroll implement here in north central Iowa.  $530.  Turned it over well and suppose to have more torque.  A lot easier to put on also( bolt on block side of starter I could get a socket on the new one, not my old one).
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 9:42pm
I put one on my Ford 555 backhoe last spring, it spins it over so fast it hardly has to run.  Will see how it does in the cold but so far I'm very pleased with it.  I found it on the internet, about $100.  Hard to beat that price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 10:06pm
Put a new Delco reduction on the C15 two yrs ago. A little over $300 from the starter/battery store.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 11:53pm
Did it to a 200 couple years ago.
https://www.allischalmers.com/forum/uploads/242/200_reduction_starter.jpg
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:58am
   While gear reductions are nice , I sure like the original starters, I have two 8050's 0ne with 11000+ hrs the other 8400hrs and both starters are untouched.
