CA Air Cleaner
ddlong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Topic: CA Air Cleaner
    Posted: 09 Oct 2020 at 10:16pm
I have a 1955 CA that is supposed to have an air cleaner with the clamp style oil cup.
Anyone put a custom air cleaner on a CA or any other tractor?  one with a paper filter?
Don in Thompson IA.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 10:41am
I've seen the top half of a cone shaped ones with a hose going to the carb.  I think pullers normally use this kind.  Might go over to the pulling section and ask where they get them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 11:46am
Some pullers use the K&N clamp-on style filters. You could gut the original filter housing and adapt a paper filter that will fit inside. A good auto parts store can help you find a filter. The snot-nosed kid behind the counter with a computer won't have a clue.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 8:54pm
It's impossible to adapt an oil bath air cleaner to work with a paper filter!  Sure, you can make a filter fit in there, but will it actually FILTER the air?  Not likely!  If you look at the housing of a correct dry filter, you can see how dirty air gets pulled in, circles around the outside of the filter with clean air coming out of the center.  Because an oil bath air cleaner was not DESIGNED to use that type of filter, the air movement will not allow it to work properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 9:41pm
While this video shows how a precleaner bowl works, the dry air cleaner is similar in that it uses centrifugal force to separate dirt particles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 10:44am
Don, there was a guy on here who did the K&N and had great pics on here years ago.  I'll see if I can find it for you.
I couldn't find the 'original' post, but I did find a newer one with pics.  It has that "PhotoBucket" crap across the face of the pics, but you can see what he did.  Ed has passed since he did this and wrote the articles.  HTH
https://www.allischalmers.com/forum/anyone-know_topic51483.html
Edited by Ted J - 11 Oct 2020 at 12:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 9:15pm
Thank you!
