Cut out relay to voltage regulator
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Cut out relay to voltage regulator
    Posted: 09 Aug 2020 at 6:45am
My 6 volt generator was on the fritz so I took it to my local automotive electrical shop for maintainence and she replaced the cut out relay with a three position voltage regulator. I assume the green wire still goes from the resistor to the generator field terminal. But where does the wire from the discharge side of the ammeter go? And since I have a three position light switch, do I now need a two position one?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 7:09am
field wire to switch box no longer needed with regulator.field on gen to field on reg.arm on gen to gen/arm on reg. Hot bat wire to bat on reg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 11:52am
Actually, moving to a VR is a nice upgrade for the 6V system. You won't need the 3 position switch for the charging side of the system anymore, but if its equipped with headlights, the switch will still take care of that side of the equation.
Wiring to the VR would be:  "F" (Field) to "F" post on Gennie, GEN or "G" to "A" post, Ammeter Neg. side (-) to BAT or "B" terminal on VR.  To Polorize, jumper wire from "B" or BAT to "A" or GEN terminal on VR for a couple seconds. You'll get a spark, that's normal. Then fire the Tractor up...
Steve@B&B
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:00pm
Thanks guys
