7000 series axle pusher bolts
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series axle pusher bolts
    Posted: 17 Jun 2020 at 7:35pm
I did a search and couldn't find anything, wondering if someone has the specs for the special pusher bolts for the two wedge design on the 7000 series. If I can get the measurements I will make up a set or two.
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 8:49pm
I KNOW THE THREADS ARE NOT A STANDARD PITCH, I BOUGHT A TAP AND DIE NUT TO FIX THE ONES I HAVE
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 9:33pm
7000 uses different bolts than 7010 and up.      MACK
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 7:10am
The two wedge design on 3 5/8" axles and larger have a 7/8" x 12 pitch thread in the wedge. I've had some pusher bolts made in the past and likely should get a batch again.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 7:07pm
Thanks for the info guys, does anyone know the overall length, length of the threaded area and the diameter of the "shaft" part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 8:21pm
My pusher bolts measure 7" overall. The end 3" is machined to 5/8" dia with 45 degree pointed end. The head uses 1 3/16" socket. You would be wise to buy a 7/8" x 12 tap to clean the wedge threads. Also be generous with the oil on the threads. If your wedges both have thread in the end two holes, get four pusher bolts. I used a 3/4" impact and when all pushers were torqued up, Hit the end of the axle as hard as you can with the biggest sledge hammer that you have. Remember, the wedge doesn't move. You push the cast center off the wedge. My 220 had a custom made dual hub full of crap for years and everything was corroded. I was expecting a long ordeal. After one hit with the sledge, things started to move. Well worth all my preparation .
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 7:07pm
Thank you very much for taking the time to measure yours Calvin.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 7:32pm
Calvin, I've read about the sledge hammer deal with multiple colored tractors. Am I to assume that the "DEVASTATING" blow is up/down on the end of the axel and NOT (forgive me Confused) in/out ? If truly smacking down, won't the end of the axel be deformed ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 7:41pm
Usually just takes one or 2 smacks, deformation shouldnt be bad - if so grinder time
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 7:58pm
Thanks Doug. On a side note, is there any chance of damaging bearings/seals ?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 6:28am
But you do smack it lengthwise, not downward.
I had to move mine on 7045 when I first got it. Right side moved pretty well, thought hey this isn’t so bad. 2 days later I had the left one moved
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 9:14am
I had the same issue with my 7045. Left side stuck tight. Broke two bolts on the wedge. Three days later I took on the right side. No issues whatsoever. Only took an hour
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 10:14am
Hit the end of the axle inward. You are not going to hit it hard enough to do any damage. It's the jar or vibration that breaks the bond between the wedge and the center after you have lots of pressure on with the pusher bolts. Was first told about the sledge trick from a JD service manager after I had broken the flange off a wedge on a 4250.
