eccentric locks on d15
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: eccentric locks on d15
    Posted: 19 May 2020 at 8:24pm
Anyone got any ideas on how to free up the eccentrics that haven't moved in 50 plus years? the previous owner put new tires on it a few years ago and one tire was put on backwards so they turned the whole assembly around to get to run in the right direction! when I turned the wheel around it is now in the far out position and can't get the locks to move to spin back in like the other side! Thanks, Kurt
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 8:45pm
Watch this video, it should help! If you have any more questions just ask.
Click the link below.
Freeing up Eccentrics
Thanks & God Bless
Dennis
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 4:15pm
I think my D14 just took lots of soaking time in solvents and every day or so I tried to hammered em back and forth a bit.
Edited by Rick of HopeIN - 20 May 2020 at 5:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 10:22pm
A good shot of quality penetrant like Kroil or Schaeffer's Penetro every day you walk by it, hit the block stops as well. Jack it up until the entire tire/wheel is off the ground, tap on each eccentric head and keep spraying. Once they move a tad, work em' back and forth when you get even slight movement, spray em' again.
If you get tired of messing with it on the tractor, pull the entire tire/wheel assy. and while still standing up, break each of the nuts on each flange and remove the bolts. Laid down with 2 each 4x4's equally spaced across the tires on each side, smack the center until the entire flange(s) pop loose. I do up to D15 rims with a bucket lined up in the center with a short 2x4 across the top of the bucket going back together, this allows the rim center to set on something while you reach underneath to install flange bolts and makes it a breeze to line them up.
Once off, you can then work on each flange in a vise to get the eccentrics freed up.
Clean them well and go back together with liberal amount of Anti-Seeze after checking the eccentric inserts as they may be thin if unit was ever run with them loose. Eccentric inserts and end wire retainers are cheap, well worth it while you have it apart as you don't want to be chasing a "clunk" that sounds like it could be coming from inside the rear end and worn thin eccentric inserts can make that clunking noise.
With blocks noted as above, wheel center will be nearly half way down the rails when reassembled laying down and you should be able to slide the wheel center freely up and down on the rails with all eccentric locking pins in the fully released position and flanges tight.
Take a good look around each bolt hole of the wheel for cracks plus around any weight mounting holes.
I mount the tire/wheel assy. and with the tire just barely making ground contact, work the eccentric locking pins back and forth and you will see the rim self-center.
Adjust your spacing, install the stop blocks where desired and lock all eccentric pins down until they hit full lock.
I also run the tractor around a bit before releasing/tightening the eccentric pins again and they should not be hard with fresh Anti-Seeze, with full weight of the tractor on them.
Not an overly big job, just takes some time and I do em' by myself.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 10:41pm
The ones I did we used heat, a 3/4" impact, a hammer and a drift.  We heated the eccentrics, ratched the eccentric head back and forth with the impact while hammering on the drift against the back side on the eccentric pin.  Don't forget to take the spring ring off the back of the pin.  Keep an eye on which way it goes when it takes off across the room.
And after all of that.  If you can't get them loose, or don't wanna be bothered, you can buy the eight I have that are loose.
This page was generated in 0.266 seconds.
