Moline UTC
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Moline UTC
    Posted: 17 Apr 2020 at 10:11pm
Getting ready to work on UTC high Crop.
Pulling the motor.
Made few supports for when I take the motor out tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 6:14am
Yesterday took off the front end and motor out of the tractor.
Using the Forklift tractor.
Got the other tractor ready to pull the motor out.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:16am
Wow Richard you go right at it. The Allis fork lift is perfect for what you do. I like seeing the pictures of the high crops you save.
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:26am
Richard,
 Thanks for the update on the Moline! I didnt even know they made a high crop?
Keep us informed, Always enjoy your projects too.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 8:58am
Richard,
Chris, they made a lot of interesting stuff. We had a big MM collector here in Newton Ia, sadly he passed away a couple of years ago. He put on an open house every July 4th, his son is still doing this I believe. Last time I was there I counted 94 pieces with an engine. Didn't even try to count pieces without!
I've posted on here before that if you're in the neighborhood on the fourth it's a good show to see and free. Here's a pic of one Dick refered to as a 'Root-Lifter'. Not sure what kind of root crop they were lifting. Seems to be on a high crop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 7:13pm
That is a nice UTC.
Sunday we got the other motor out and change out the clutch and interlock from the parts tractor to the UTC.
Also did some cleaning of the Manifold.
Though it was going to be okay till I seen a 2" hole appear.
Order a new exhaust manifold.
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 7:47pm
Nice tractors You have there. Always had a soft spot for Molines. Grandpa had a ZB when I was a kid and Dad has a UB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 9:01pm
Work on the UTC last week and over the weekend-
Got the motor back in neat to get to drive it around.
Still has more work needed.
Use the weld trick to get out broken bolt.
Also the torch is most needed item when working on these tractors.
