m2 header height question
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: m2 header height question
    Posted: 19 Aug 2010 at 4:39pm
i bought another m2 with the header height switch on the top w the other buttons but not the 3 position knob by the shifter. the one in the other machine is junk
do i need it? will it worl without this? should i add it? how do i wire for a series 3 head?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 5:00pm
You will only need the 3 position switch to run a floating header with the robot, you can run any other header (or even a floater if you dont want the robot) without one. We have an L2 that was adapted to run a series 3 header that has extra wires connected to the reel speed button with a separate add-on connector to connect it to the solenoid on the hydraulic reel speed on the header.  Hope this helps.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 8:49am
i want the real speed and the robot
