Model 64 snowblower
Jschlangen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jschlangen Quote  Post ReplyReply Direct Link To This Post Topic: Model 64 snowblower
    Posted: 04 Jan 2020 at 3:52pm
Trying to find or make a snowblower fit my 5020. Looking for pictures of how the model 64 hooks up to the front PTO. Thanks in advance for any help.
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 9:51am
There’s a fairly complex mess of heavy brackets, belts, and pulleys. For some reason the snowblower electric clutch part number is different than the mower deck electric clutch part number. I have a set of brackets and the snowblower manual if you need something specific. The whole setup is kinda heavy and I think it was prone to breaking the front end of the tractor and the brackets. Also need a hydraulic cylinder and rear port. You might be better off getting a rear snowblower. Not sure if the reverse gears are adequate for backing up with one. I am very sure that the actual snowblower is a Mckee that Allis or Simplicity adapted to fit the tractor with a big mess of bracketry.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 8:11pm
the electric clutch will run both the belly mower and snow blower as I have both. there is a very heavy front mounting bracket that bolts to the frame and I haven't had any problems with it. as for the snowblower itself it has a Made in Canada tag riveted to it. if you would like pictures send me a phone number and I can text you some
Life is tough,but it's tougher when you're stupid. - John Wayne
