B fan belt
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: B fan belt
    Posted: 13 Sep 2019 at 11:12pm
Hi all can anyone tell me what size fan belt I need for my Allis B with a 6 volts generator
Thanks in advanced
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2019 at 8:11am
Might be in the specifications section of the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
But might not be correct for a different era B from the date of that shop manual. You might be able to measure the length with a 1/2 or 5/8" wide steel tape measure. Tape should be the same width as the belt, 5/8" for a B belt.
Gerald J.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2019 at 4:15pm
This the Allis part # 70209656. No idea what the actual size is.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2019 at 9:09pm
I have two 'B's with generators. Both belts measure 38 inches outside.  One has a 5/8 wide belt and the other has a 1/2 in.  The 1/2 in. one rides in the  crank and generator pulleys better--about  1/16 in. below the outer edge of the pulleys. Both of these tractors get a lot of use.
Edited by Alberta Phil - 14 Sep 2019 at 9:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2019 at 5:57am
That AGCO number will cross to a GATES belt TR22373 which is 11/16X37-7/8.
This page was generated in 0.127 seconds.
