round baler operation
js case View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote js case Quote  Post ReplyReply Direct Link To This Post Topic: round baler operation
    Posted: 12 Sep 2019 at 10:05am
Bought a white top baler a few years ago. Nice condition. Set in my shed since. Got out last night and tried to run but top belts will not turn. Roller is turning.  Anybody have any suggestions as to  why belts are not turning. the other rollers are free and turn but the belts just seem to not grab on the drive roller.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 11:25am
Run some hay into it. Then they'll turn. Darrel
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2019 at 3:41pm
before you put too much hay into it, gotta make sure the brake is not stuck or you will have more problems...
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 2:36pm
Sometimes after sitting all winter it takes a little hay fed into the chamber to start them turning. Stand behind the baler, in the bottom right hand corner you will see a brake band. Loosen up that band and make sure it is not stuck to the drum. You need To do this after the baler has set for any length of time.
