Weep Hole
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: Weep Hole
    Posted: 20 Aug 2019 at 3:59pm
On my 7040, the weep hole on the oil cooler is slightly wet right after startup, then dries up once it warms up. Is this normal?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 4:10pm
Its not a difficult job to fix, I done my 7060 year or so ago,they're 2 different o-rings in there, 1 for oil,1 for coolant, I guess the main point is, don't mix them up. I looked up the parts on the ago parts page
Ya can do a search of my posts, I put a couple pictures
Edited by Michael V (NM) - 20 Aug 2019 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 7:14pm
It appears to be diesel fuel though. Right above the oil filters out of the tiny hole there, not a large amount, just a little dribble. At least I thought it was diesel fuel??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 9:38pm
No, it will be engine oil or antifreeze.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 10:46pm
Normal,no. Precursor to fixing cause. You have an 0-ring failing. It won't get better.
