190XT Tie rods
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Tie rods
    Posted: 24 Jun 2019 at 9:37pm
When I restored my 190XT last year, I put new tie rods on both sides (chinese aftermarket I suspect).  When turning sharp left turns, the tie rod end would slide in the tube even though the clamp was as tight as it could go.
Played around with it this past weekend and I started by centering the front plate. Now both sides will slide when making their respective turns.  I ground a bit of metal out of the clamp to get them to close tighter, but they still slide.
I am at a loss here.  I am getting tired of having to keep resetting the front wheel toe in.
Any assistance would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 9:39pm
Them come from AGCO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 9:49pm
Can`t remember.  I think I got them from my local AGCO dealer.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 9:52pm
I have had the same problems with my 180, i also put new ones on and they will slide if i hit a hole or something, remember on here they say to grind off clamp on old tie rods and double them up on new ones, i havn't done this yet but plan to
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 6:04am
Keep the clamps from old tie rods and put on new. New are junk.     MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 6:40am
What MACK said!
Wink
I am a Russian Bot
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 8:59am
I installed a new pair on my WD last year. I am pretty sure they were Chinese. Really good price. They looked just as good as the the originals, but the split in the female ends were not wide enough. A cutting disc in my right angle grinder took care of that issue in a hurry. Hope this helps.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 10:03pm
I had to do what Mack said.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 9:20pm
I had this same problem. Drove me crazy !
