Hydraulic Cylinder for WD45 and wheel disk |
Post Reply ![]() |
woodman Steve ![]() Silver Level ![]() Joined: 19 May 2011 Location: Indiana Points: 70 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Dec 2018 at 10:11am |
Where can one find a one way cylinder that will work with my WD45 system for my wheel disk?
Steve
Two WD45's |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Any cyl with adequate length and the correct ends will work. You would just put a vent cap on the unused end of the cyl. if it's a two way cyl.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Needs to be a hi pressure cylinder and hose.
I have one that I don't use any more that I would sell. MACK |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8572 |
The original AC cylinders work best.They are still out there. High pressure,low volume.
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
have one i may sell also;
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5047 |
I have a few of them available. Some are NOS.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3059 |
I have heard that for years but never have had a problem using regular cylinders on AC tractors.Have you ever actually had a problem?
They will stretch the bolts on a low pressure cylinder then blow orings + will lift slow. MACK
Guess I've been lucky never had a problem, have a regular cylinder on a NH mower now I've used quite a bit hooked to a D15 and a WD.What brand cylinder were you using when it happened?
alchpuller ![]() Bronze Level ![]() Joined: 17 Dec 2015 Location: Goddard ks Points: 30 |
I have some aircraft MLG cylinders, 3000 psi system mineral oil fluid , 303 fluid works good 18 in travel extend only, you pay shipping and 10$ a piece, I use them on a bale mover and they work good with my WD45
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
I have a 2 way Oliver cylinder I used on the 45 for several years, to lift the corn planter. Never had a problem, but I never let it hammer after it was extended all the way. If you raise it up out of the ground and move the lever to the hold position, you'll never have a problem with any 2 way remote cylinder. It will be slower than a regular Allis cylinder.
I eventually found a cheap Allis cylinder at an auction. Gave $8 for it and then spent about $30 and 3 hours of my time to make a new rod and put new packing in it. |
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3274 |
Most modern cylinders are made to handle at least 3000psi. Unless you have rebuilt the pump, it's probably not getting that high of pressure anymore.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
Dad's WD pushed a wagon hoist cylinder apart once. After that Dad gave strict orders to not let the wagons go but so high.
Wink I am a Russian Bot |
Post Reply ![]() |
